Creating a horizontal alignment only using elevation points
I'm having problem creating a horizontal alignment with the given data I have. I'm only given my station point with no bearings and only their elevation points. How do I create a horizontal alignment in autocad civil 3D
Pointdump
L,
Welcome to the Autodesk Forums.
Please post your data. Is it a point file?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
This is all that was given
Pointdump
L,
Did you mean to attach something to your post? If you responded from your e-mail, it won't allow you to attach any data. You'll need to sign into the forum to attach a file.
Dave
Dave Stoll
Las Vegas, Nevada
igi_pop
Well, an alignment can be created in many ways. All depends what you need.
For instance, you can use "best fit" and see what you get (from what little you wrote i'm guessing it won't do)
...to next post..
Custom build;ASUS Z790 Prime Z790-P;i5-12600KF @3.6GHz; ASUS RTX3070Ti 8GB GDDR6X; Win11pro x64; 128GB RAM DDR4; SSD 2TB 980 PRO M.2, PCIe 4.0 x4,
"I'd rather have a bottle in front of me, than a frontal lobotomy."
AutoCAD Civil 3D Certified ProfessionalAutoCAD Civil 3D Certified Professional
igi_pop
Alternatively, you can draw it much like you would draw a vertical profile! I often do that (or convert poly) since i do geotechnical stuff, and curve radius (ect) rarely mean anything to me.
Cheers
