Civil 3D Forum
create surface from autocad points
5 REPLIES 5
alaahashem
2566 Views, 5 Replies
hi every one
i have a problem when create asurface from cad points
points have elevation between (670 -685 ) but when i create surface from (add objects - points ) or when convert autcad points it take elevation between ( 200-210)
i don`t know where is the wrong
any one can help me
file attached
5 REPLIES 5
Pointdump
in reply to: alaahashem
Alaa,
Sounds like a Feet-to-Meters conversion is happening. Your drawing uses Feet Units. Please provide more details on how you are adding those points to your Surface.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Pointdump
Alaa,
In your drawing I am unable to add those points to a Surface. I can't isolate them, even if I detach the two Xref's. I can Data Extract the points to a CSV file and then add them to a Surface, and that shows an elevation range of 676-683 Feet.
Dave
Dave Stoll
Las Vegas, Nevada
Jeff_M
I was able to create the surface from the Acad points (Surface->Definition->Drawing Objects->Points...selected all the points by window) and the elevations are as you described.
Jeff_M, also a frequent Swamper
alaahashem
in reply to: Pointdump
thanks a lot
yes I found drawing setting as feet so it make my problem
alaahashem
in reply to: Jeff_M
thanks for your help
I CHANGE DRAWING SETTING FROM FEET TO METER SO IT GO WELL
Rail Community
