hi every one
i have a problem when create asurface from cad points
points have elevation between (670 -685 ) but when i create surface from (add objects - points ) or when convert autcad points it take elevation between ( 200-210)
i don`t know where is the wrong
any one can help me
file attached
Solved by Pointdump. Go to Solution.
Alaa,
Sounds like a Feet-to-Meters conversion is happening. Your drawing uses Feet Units. Please provide more details on how you are adding those points to your Surface.
Dave
Dave Stoll
Las Vegas, Nevada
Alaa,
In your drawing I am unable to add those points to a Surface. I can't isolate them, even if I detach the two Xref's. I can Data Extract the points to a CSV file and then add them to a Surface, and that shows an elevation range of 676-683 Feet.
Dave
Dave Stoll
Las Vegas, Nevada
thanks for your help
I CHANGE DRAWING SETTING FROM FEET TO METER SO IT GO WELL
