Create point groups on import? and COGO points to blocks on separate layers
MP07
MP07
What I want is actually very simple but I'm trying to find a way to make it as simple as possible and so far I haven't solved this.
So I have a bigger number of points that I want to import (let's say 2000 points) and they all should be divided to  around 40 point groups.
I defined a user point style like this
point number - easting - northing - elevation - raw description
I found out how to put certain points into points groups based on their raw description on the video below
https://knowledge.autodesk.com/support/civil-3d/getting-started/caas/screencast/Main/Details/fb33b1f...
but since I gotta have 40 points groups it means I have to do that at least 40 times! Also, I need to create a separate layer for each point group and again I need to do that 40 times.
So that's 80 repetitive actions!
I was wondering if I'm missing an option maybe on import where civil could create a point group based on raw description, and also a layer named exactly as raw description and putting that point group on that layer.
Furthermore, later I also need those COGO points to be exploded/converted as blocks
(Home ribbon> Create Ground Data Pane> Points > Create blocks from COGO points) <- this is awesome but all the blocks/blocks reference go to the same layer.
If I would want them on separate layer again I would have to repeat this action at least 40 times selecting one point group and then converting it to autocad block...
I mean where does Civil accelerate this workflow?
Jeew-m
Dear Friend,
As far as i know there is no automated method to make them in to groups at once.
But there is one workaround. It will not be much effective if you are using this work only once. If you use this more often that would be much useful and time saving.
Create description keys for each of your point codes that you need a group. In creation of description keys you can assign a layer also. You can save the drawing with description keys as a template for future needs.
Then import the points. it will show the points in assigned options in the description keys such as markers, labels, layer etc., but still no groups.
You can start the normal way of create point group and from the 'Raw Description Matching' tab you can assign the description keys to create point group.
https://www.youtube.com/watch?v=Von8oCwYcTk
It is time consuming for the first task but for same task in future it will be much more convenient.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
MP07
Thx mate,
I'll take a look into it, I do use it often(or almost often) but every time it will be different layer names so I guess one template to rule them all is not going to work if that is was you mean.
tcorey
It is not difficult to use LISP to move those points to a layer that matches the description or the Point Group name, but creating a point group and setting its properties doesn't look to be available in LISP. I think you'll need .NET for that.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
MP07
Tim,
a LISP indeed came in handy at the end. I'm not sure if I can post links here so I won't, but it's called POINTSIN.
It's great, I adjusted the code and the dwg template it uses to suit my needs.
Thanks everyone, I hope they will introduce some new features in future versions of Civil that will solve the problematic we talked about here.
Mauro
Jeff_M
@tcorey, lisp can be used to create pointgroups and set the query properties. Here's an example of doing this, creating the group with a name and setting the IncludeRawDescriptions query to be the group name with the * wildcard.
;;Function to get or add a PointGroup
(defun CreatePG (grpname / C3D C3Ddoc ptgroup grps query)
  (vl-load-com)
  (if (and (setq C3D (strcat "HKEY_LOCAL_MACHINE\\"
			     (if vlax-user-product-key
			       (vlax-user-product-key)
			       (vlax-product-key)
		 C3D (vl-registry-read C3D "Release")
		 C3D (substr
		       C3D
		       1
		       (vl-string-search
			 C3D
			 (+ (vl-string-search "." C3D) 1)
		 C3D (vla-getinterfaceobject
		       (vlax-get-acad-object)
		       (strcat "AeccXUiLand.AeccApplication." C3D)
	   (setq C3Ddoc (vla-get-activedocument C3D))
	   (setq grps (vlax-get C3Ddoc 'pointgroups))
    (progn
      (vlax-for pg grps
	(if (eq (vlax-get pg 'name) grpname)
	  (setq ptgroup pg)
      (if (not ptgroup)
	(setq ptgroup (vlax-invoke-method grps 'Add grpname))
      (setq query (vlax-get ptgroup 'querybuilder))
      (vlax-invoke query 'clear)
      (vlax-put query 'includerawdescriptions (strcat grpname "*"))
    (vlax-release-object c3d)
  (princ)
;;once the above is loaded, call the function with the desired PointGroup name
(createPG "EOP")
tcorey
Thanks, Jeff!
Tim Corey
Redding, CA
