Create Grading with Multiple Slopes
nmahonVSCZR
nmahonVSCZR
I am trying to use grading tools to design a pad.  The outside of the pad is based on an existing surface.  I have created a feature line for the outside.  The pad itself needs to have a flat work area.  The work area is fixed horizontally but can be adjusted vertically to balance my cut/fill volumes.  I need to create a grading that runs from the flat area at a slope of 1%, which then changes to a grade of 3:1 to target the outside edge of the pad.
I know there is a work around to do this by creating grading from each line separately.  Just wanted to see if there is a way to do it in a single grading.
neilyj666
I can't quite picture what you are trying to do (a sketch would help) but have you considered using a corridor for this?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
nmahonVSCZR
Below is a screenshot of a rough approximation of what I need.
andrewpuller3811
If I am getting this right, and you wish to keep the shape of the white toe of cut -
Create a grading from the flat area out at 1% for a set distance beyond the white toe of cut line. (you may need to make a separate feature line around the flat are to compensate for the internal corner)
Make a surface out of the 1% grading and the flat area feature line.
Set the toe of cut feature line elevations from the surface just created.
Create a grading from the white toe of cut feature line to the original ground at 3:1.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 11
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2023
nmahonVSCZR
The shape and location of the white line is determined by the intersection of the 3:1 slope from the yellow line and the 1% grade from the blue line.  The method you have described is what I have been doing and works well, just a little inconvenient to have the grade to distance feature line in the drawing.
If there is no other solution, I'm happy.
