Create Data Shortcut of Pipe Network
Message 1 of 12
Hello all,
I want to create a data shortcut for a pipe network so I can make the network "Active" in my current dwg file.  The pipe network I want to make active is in a separate file, so how can I do this?
-It seems that I already have a data shortcut from a surface file, and I can't figure out how to create the data shortcut for the pipe file, then copy it into the active file.
Replies (11)
Message 2 of 12
troma
Open the drawing with the pipes in it.
Go to Ribbon > Manage > Create Data Shortcuts (big button on the left)
This is assuming that you have already set your working folder and shortcuts folder correctly for this project.
Mark Green
Working on Civil 3D in Canada
Message 3 of 12
I see.  When a data shortcut is created in a file you set the working directory and it creates a folder with the xml files in it.  So, we're opening the new file that we want to use, and saving it as an xml file in the same folder that was created previously by the program when we initiated the first data shortcut.
Is that what we're doing?
Message 4 of 12
Where is manage in the ribbon?
Message 5 of 12
I types manage in the command line and got this....please see the attachment.  From here, not sure how to operate this "Link to a Data Shortcut" dialog box.  -Am I on the right track?
Message 6 of 12
I don't see the manage tab anywhere on the ribbon...please see attadchment.
Message 7 of 12
troma
I've never seen that box before.
Here's what I was talking about:
Mark Green
Message 8 of 12
Well, I couldn't find the "Manage" in the ribbon.  However, I did create the data shortcut in the file and it added an XML file in the working folder for data shortcuts.  I was able to add that in the file I want to work in, so the problem in solved now!
-In the pipe file I went to Toolspace - Data Shortcuts (Right Click) - Create Data Shortcuts.
Then I checked the working directory folder and that created the XML file in the pipe network folder, then went to my active file and it's in my data shortcuts tab in the prospector.
Thank you
Message 9 of 12
troma
Sorry, just saw your last post.
So, I'm not sure. I've only used up to 2013. Maybe they changed it in the newer versions. What release are you working in?
Mark Green
Message 10 of 12
Are you working in Civil 3D 2015?
Message 11 of 12
O.k., I'm working in 2015.  I figured you were in a previous version.  However, from what you said in you first message I was able to figure out what to do.  Thank you again!
Message 12 of 12
troma
Cool, glad you found it.
I just tested in 2011 doing it the way you said, and it does activate the same command. I wonder where they hid the buttons though... anyone who knows?
Mark Green
