Create corridor from AutoCAD objects in section views
djolegaf
djolegaf
Hi everyone,
I am working in road construction company as quantity surveyor and I got existing ground data from my surveyors, put it in a Civil 3D and created surface and section views from proposed alignment. Problem is that original design was created in some software that use AutoCAD as base and I have original sections as AutoCAD objects. My question is: is there any way to create corridor from these CAD objects that I have? I inserted all sections to proper place in Section views in Civil but I don't know how to create corridor from CAD lines. I will be glad if anybody can help me with this problem. Thanks in advance!
joantopo
Sincpac C3D
http://quuxsoft.com/SincpacC3D_Help/SP_DigitizeSectionTo3DPoly.htm
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
djolegaf
Hi, thanks for your reply, but I looking for solution inside Civil 3D (without add-ins for Civil) or with some free add-in, since this is for my company needs, and they don't want to pay for additional software.
