Grading with intermediate plateau
JFN_KSH
Message 1 of 11
JFN_KSH
In some area of my project I need to grade with intermediate plateau (see pics). Is there any way to achieve this in Civil 3D?
Replies (10)
Message 2 of 11
Corridors or feature lines.
If it is feature lines, just offset the feature lines the desired distance and height.  You can also offset the feature line generated by the grading objects.
Corridors have a benching daylight assembly.
Hope that helps,
Message 3 of 11
neilyj666
I'd agree with @cwitzel but my preference would be corridor methods.
I would avoid attempting to do this with grading objects as your drawing is almost guaranteed to crash (as I know from experience).
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 4 of 11
JFN_KSH
Any suggestion on which sub-subassembly to use?
Thanks a bunch for your help!!
Message 5 of 11
JFN_KSH
ok... I just saw the DaylightBench... Seems like my fix... Thanks again!!!
Message 6 of 11
neilyj666
Yes this should work but there are several for various uses
Message 7 of 11
JFN_KSH
Can I apply the sub-assembly to a feature line? or do I have to create an alignment at the perimeter of my building & apply that sub-assembly as a corridor?
Message 8 of 11
neilyj666
Yes - you can't currently use a featureline as a baseline for a corridor so you will need to use create a horiz alignment and profile from your featureline. I would also add small radius bends at the corners to assist with the modelling but you will get the inevitable "bowties" appearing at the corners
Message 9 of 11
JFN_KSH
I'm lost now... My first two slope needs to be at 1:2 slope & all of the rest needs to be at 1:3 slope...? I can't seem to figure it out... Now looking into the Subassembly composer...
Message 10 of 11
neilyj666
It can also be done using the generic links - what is your first 1:2 slope targetting??
Message 11 of 11
JFN_KSH
My First 2.00:1 max height is 4.5m, The second 2.00:1 max height is also 4.5 & then all the others bench need to be at 3.00:1 with max height of 4.0m...
