Civil 3D Forum
create contours from existing points in a drawing
10 REPLIES 10
Message 1 of 11
36556 Views, 10 Replies
Can you create contours from points already in a drawing? I have pts in a drawing, but I can not reload them. is there a way I can select the points that are already there to create my contours?
10 REPLIES 10
Message 2 of 11
What a coincidence.. just few minutes ago replied in a very similar question.Smiley Happy
Yes, you can. Through C3D Toolspace, in the Surface definition -> right-click on the "Drawing Objects" element -> Choose "Points" from the list, and it's done.
I hope this helps.
- Lambros
Message 3 of 11
here is what I have
Message 4 of 11
when I do that it says 0 found
Message 5 of 11
Adam_Farnsworth
I was able to create a surface in both of those drawings with the blocks 🙂
Here's a picture:
Windows 7 x 64
ATI Radeon HD 5700 Series
12 GB Ram
i7 920 @ 2.67 GHz
Civil 3D 2011, 2010, 2009 and occasionally 2008 still (unfortunantly)
Message 6 of 11
Adam_Farnsworth
They're not actually points, they're blocks set at elevation.
Windows 7 x 64
12 GB Ram
i7 920 @ 2.67 GHz
Message 7 of 11
ok, I got it I had to choose blocks instead of points. Thanks so much for your help!
Message 8 of 11
rl_jackson
See Attached it is quick and dirty, I am assuming you are using C3D11 since I got no warning.
If you got that from a surveyor I would recomment asking for the ascii file, I am unaware of a way to convert Carlson Points
This would also allow you to import the point to create fault lines, etc......
Rick Jackson
Survey CAD Technician VI
Message 9 of 11
in reply to: Adam_Farnsworth
Yes, but you just have to be very careful. Objects will not be linked dynamically with the surface, so, if you modify them (e.g. move), the surface not going to be marked as "modified". You will have to remove the previous definition and add again.
- Lambros
Message 10 of 11
AlmasSuljevic
Here is how I managed to do it.
1. Explode all points
2. Set Create Points command to not prompt to enter point information (set automatic). See image.
3. From Home ribbon, Points, Convert AutoCAD points
4. When prompted which points type ALL
5. Create surface and add these COGO points to it
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
Message 11 of 11
I have points and polyline through points, can I make my polyline to 3d polyline same points elevation in each vertex
Rail Community
