Create a Tin Surface from .laz file?
stevenZ45DY
Observer Observer
Message 1 of 22
stevenZ45DY
Observer
Observer
I have a lidar point cloud file in (.laz). I would like to create a TIN surface in Civil3D from this data but cannot directly create a surface. What is the best free method to convert this file and begin creating a surface in C3D?
Thanks!
Replies (21)
Message 2 of 22
Domzinator
This can be imported into recap and then you will be able to open the recap point cloud file in civil 3D
Civil 3D Certified Professional
Message 3 of 22
Pointdump
Hi Steven,
ReCap has a free version. You can use that to convert a laz point cloud into an rcp file that Civil 3D can use.
Your other free options are to convert the laz into an xyz file. For that, either las2text in lastools(also in QGIS) or CloudCompare.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 4 of 22
sirjoelsph
We use DotSoft's LidarTools.  They've made this portion of their great add-on tools free for everyone.  Direct from LAZ to Civil 3D surface without dealing with ReCap in the middle.
https://dotsoft.com/blog/?p=508
-JOEL
Message 5 of 22
RobertoJJoaquin
@stevenZ45DY You need to have the RECAP program installed, upload the point cloud, generate an rcp file, and after that in Civil 3D there is an option to create surfaces from point clouds, Another method is to change the laz file to an XYZ file but the file would be very large,
Leave a like! If you found this helpful.
If your query has been solved, mark it as a solution. This will help other people find it easily later.
¡Deja un like! Si te fue útil lo indicado.
Si tu Consulta ha sido solucionada, marca como solución' esto ayudara a otras personas a encontrarla fácilmente a Posterior.
Message 6 of 22
stevenZ45DY
Observer
Observer
My .laz file is a big square tile, much larger than my project area. Can I crop the tile down to my project area in Recap?
Message 7 of 22
stevenZ45DY
Observer
Observer
It appears that I cannot export my needed file from the free version, only Pro. Is this correct?
Message 8 of 22
ianjchap
Hi @stevenZ45DY
First convert your .laz to an .LAS file
https://www.google.ca/search?q=convert+laz+to+las&hl=en-US&gws_rd=cr,ssl&ei=gwKiWITVE5T0jwOS8Z_gDg
Then create a Surface from LAS:-
https://forums.autodesk.com/t5/civil-3d-forum/las-to-civil-3d-surface/td-p/9792751
Ian Chapman
If you found this post useful, please Like the post.
If this post helped you successfully solve your problem, then click on the ACCEPT SOLUTION button.
Message 9 of 22
Pointdump
Hi Steven,
"Can I crop the tile down to my project area in Recap?"
Yes, use "regions" to crop.
"I cannot export my needed file from the free version..."
What happens when you try? Should work.
Dave
Dave Stoll
Las Vegas, Nevada
Message 10 of 22
neilyj666
@sirjoelsph Unfortunately Dotsoft made the commercial decision to stop supporting the latest version of Civil 3D (2025) with the free tools
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 11 of 22
sirjoelsph
Dang @neilyj666 , you're right.  And they didn't make it cheap either...  Time to figure out yet another workaround.
-JOEL
Message 12 of 22
J-Porter
You can't do this directly in Civil 3D.  If you have the AEC Collection then you have access to Recap.  Take the file into Recap and the export it from there.  Take a look at this:  https://youtube.com/playlist?list=PLODyPJ02lt5-PE0GdDgZ93AyBLVGyI5XH&si=8RiW4Sv2AydOI26c
Message 13 of 22
Pointdump
Hi Jason,
Nice cut-to-the-chase videos! Good job!
Dave
Dave Stoll
Las Vegas, Nevada
Message 14 of 22
J-Porter
Thanks, Dave!!!  I hope they still work.  I only make the videos because I know I'm going to forget the process later.
Message 15 of 22
Pointdump
Hi Joel,
I just saw >>>Here<<< that Terry Dotson died in December. I wondered why he hadn't posted recently.
Dave
Dave Stoll
Las Vegas, Nevada
Message 16 of 22
J-Porter
Sad!!!  So sad to hear this.
Message 17 of 22
neilyj666
@Pointdump 😲 never knew that about Terry.....
Message 18 of 22
teerawat.pSCHYQ
Hi @stevenZ45DY   please try what @Domzinator reply to you,  you can use Autodesk Recap to import Laz file and then In Civil 3D you can import that recap file into Civil 3D, it like my project like this
then open Civil 3D, then go to Point Cloud panel > Select Attach
then in the home tap, go to Create Ground Data Panel then Select Surface>Create Surface from Point Cloud  like this
Message 19 of 22
fcernst
Wow.. he really helped me.. always open to implementing my Tool ideas. We had a lot of back and forth emails working on Tool ideas over the years.. will be missed tremendously. He was a good friend..
Fred Ernst, PE
C3D 2026
Ernst Engineering
www.ernstengineering.com
Message 20 of 22
sirjoelsph
Thanks Dave @Pointdump, I hadn't seen that yet.  You're right I hadn't seen Terry post in a while, and he's usually right on top of topics like this.  It looks like Carlson Software acquired Dotsoft, so his work will at least still be around and supported.
-JOEL
