Civil 3D Forum
Corridor wont build assembly - wont display
5 REPLIES 5
kevin.moranVRCAR
361 Views, 5 Replies
Hi
I am using the OverlayMillandLevel 2 subassembly. How it wont build on my corridor, targets are correct. anyine seen this issue before??
Labels (1)
5 REPLIES 5
Hi @kevin.moranVRCAR, can you upload your file?
Camilo Fernández
Civil engineer | Specialist in design, construction, and maintenance of roadways
LinkedIn
Thanks, please see drawing attached.
My targets are:
Left Sample Offset Target: - Yellow line Left
Left Trim Offset: - Road Edge Left
Right Sample Offset Target: - Yellow line Right
Right Trim Offset: - Road Edge Right
Corridor - (Inlay)
Assembly - (Inlay 45mm)
Issue is corridor is not visible, cant create surfaces, won't display in cross sections etc..
Hi @kevin.moranVRCAR, I saw your file. The problem is that you have not assigned the surface target. This subassembly requires a surface target. Indeed, it is the only mandatory target.
Assign it, and it will fix your issue. (see image and file attached)
Best regards!
Camilo Fernández
LinkedIn
Thank you very much for taking the time to reviewing and solving this problem.
Would you have any solution to the below question:
I set my elevation target and my offset target for my corridor, however i want the elevation target to continue along the same slope to the offset point (red line in snip) rather than being transferred straight across (blue line in snip). Do i need a certain sub assembly? thanks
Hi @kevin.moranVRCAR, I'm glad I could help you.
Regarding your second question, I am afraid I need a bit more context to answer. Let me ask you
1. Is this related to the same previous issue? Are you using the same subassembly?
2. Is this part of the cross-section a shoulder or a lane?
3. Is the section in your image what is currently happening in your corridor? If so, the assembly seems to behave similarly to what you want.
Best regards!
Camilo Fernández
LinkedIn
Rail Community
