Corridor - Side Ditch issue
krkec
krkec
Hi all, I am creating corridor with basic lane with added SideDitch on the side. When changing in Realistic View only lane is rendered, ditch remains empty. Am I doing something wrong? Please help.
jjfuller
This is all in code sets.  Open the code set you are using for the corridor and verify that a render material has been assigned for the link code in the subassembly.
Jon Fuller
Infrastructure Design Suite Premium - Latest Version
Civil 3D - Latest Version
krkec
Hi Jon, Yes I did open the subassembly properties and when attempting to change render material nothing happens.
Tried to change any of parameters but it seems that all thing is locked for editing.
Take a look to the jpeg.
Thanks for your time.
BR Matej
jjfuller
The render Material will need to be edited in the Code Set Style, not the subassembly properties. In your case, edit the Code Set Style "Basic" and assign a render material for the ditch link codes. Rebuild the corridor and it should work fine.
Jon Fuller
krkec
Jon your advice solved my problem.
Thanks a lot & have a nice day!
Matej
