I've got unique problem here. I've managed to get my corridor shown properly in section views with corridor point label styles working in the view. However, after a certain horizontal PI in the alignment containing the sample lines, the corridor point labels not longer show.
The corridor itself is on different alignment.
Any ideas of how to correct this glitch?
EDIT:
After PI in the alignment, no labels from corridor POINTS will show. I've got link labels that still work properly, just not point labels.
Can you post the dwg?
If not please post screen shots of the subassembly, sample lines in plan view, and section views (showing both the correct & incorrect display portions) .
I can't post the whole drawing due to its size. I'll see about putting up some screenshots when I get a chance. My "work around" so far is just to use sample lines on the alignment that the corridor is using.
