Has anyone experienced an issue with the parameter editor while in the corridor section viewer in which you override one parameter (for instance, a ditch slope), and every single parameter is marked into an override state? I have two sets of assemblies (one that I am using for superelevated curves, and one for the straight tangent portion of the corridor. It seems to only be an issue in the superelevated assemblies. When I override the other set of assemblies it behaves the way I want and only overrides the one feature that I type in. However, I checked the assembly and subassembly properties and can't see why the model would be doing this. I attached a screen shot (the grey highlight is the only line that I changed).
Andrew
I think I may be having a similar issue. I'm trying to increase the width of a ditch and when I change the parameter, the whole left side of the road goes away. I posted a few hours ago, but no replies so far. I was going through these old posts to see if anyone else had the same issue.
Did you ever solve this?
