Heloo All,My offset target not catching multiple object,see attached picture,i have selected target-1 and target-2 ,when I get result only first selected target connected,but target parameters its showing target-1 and 2.Please Help me.
Solved by Jowennl. Go to Solution.
would it be possible to share the file?
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
Hi @Anonymous,
Without a copy of your PKT or custom subassembly, it will be harder to debug this. You mention you create feature line from corridor, If that corridor is A and you want to use the same corridor A to target it self then it will not work. Better create another corridor B that will target the featureline from the first corridor A. If you can share your PKT it will be better as maybe your insertion sides is pointing to left and not on right.
Please see some initial guides below:
Cheers,
Jowenn
Jowenn Lua | Retired Account See My New Profile Here
AU 2023 CES600726 – Getting Started with Generative Design in Civil 3D: A Beginner’s Guide
AU 2020 CES473668 – Supercharge Your Dynamo Graph with Civil 3D Toolkit
AU 2019 CES319333 – Dynamo in Civil 3D Introduction Unlocking the mystery of scripting
AU 2018 CI225967 – Using Automation in Civil 3D for Construction Documentation and Exports
AU 2017 CI123653 – AutoCAD Civil 3D and Subassembly Composer— Real-World-Practice Tips and Tricks
Thank you for your effort,please find my attachment of PKT.
Hi @Anonymous,
Please see attached animated gif below as a guide. I think your featureline is in elevation 0 and needs to be redesign to look correct. I move it to elev 4.82m as a demo only.
Cheers,
Jowenn
