Corridor Generate additional lines
muhammad.IsmailD4493
Hi Everyone.
By looking at image below you will sure clearly understand the issue with why corridor generated those offset lines while not been asked to draw.
Please share your knowledge.
Thanks and regards
arturopolanco
Hi @muhammad.IsmailD4493
Can you share printscreen about your Assembly and Subassemblies?
Arturo Polanco
AEC Solutions Specialist - Civil Infrastructure
Youtube | Twitter
Hi @arturopolanco
Please refer below images for your review.
Regards
nkiakas
@arturopolanco has right. Most of these problems come from the subassemblies.
Are the subassemblies of the snapshots custom with subassembly composer or used the build in subassemblies?
Could please also share your file?
Regards
chriscowgill7373
I cant tell what is going on from the screenshots, but, Daylight general, if you get over a specific elevation for the slope, it will go to the steep slope condition and will throw a guardrail shoulder into your section, causing the section to jump out whatever the width of that shoulder is.  In Imperial, it is a 2' shoulder at 2% that gets added.  We instruct our users to make sure it is set to 0' for the width if you are not planning on using it.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2026 on Windows 11
