Corridor does not solve 90 degree angle
Beka_Tchigladze
Advisor Advisor
Beka_Tchigladze
So I have an alignment and assembly done with the left and right side,
but corridor doenot solve 90degree angle, I tried to change frequency and angle also but it doesnot solve
Beka Tchigladze
Infrastructure Design Engineer | BIM Automation Developer
Autodesk Developer Network (ADN) Member
Autodesk Certified Professional: Civil 3D & AutoCad
LinkedIn | Autodesk App Store
tcorey
Often, designers will use a small curve in the corner to help civil 3d around the corner.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Beka_Tchigladze
Yes Me also but for some structures with the wide width at some point it creates a bowtie so this is very boring to do separate baseline for this issue,
so I noticed that when I appoint vertical target to the assembly for pile depth or the Kerb depth this cause the problem otherwise it works why?
Beka Tchigladze
cneelyPABBX
Maybe you could skew the corridor where the PI is? Watch this video and see if it helps any.
https://www.youtube.com/watch?v=__bDC0OmObM
Beka_Tchigladze
no thank you this is not what I need
Beka Tchigladze
Beka_Tchigladze
So, I solved this problem that I use Transition editor, this was an assembly which could follow vertical target, so since I would assign vertical target it was not solved the corner anymore, So I used transition editor to neglect vertical target and have a various depth for my curb thank you anyway.
Beka Tchigladze
