Corridor Curve Irregularity
aniruddh_ab
aniruddh_ab
I'm trying to curve the Trench "Corridor" in image 1 but the corridor is getting curved not as per the design/layout.
But in the image 2 the Trench "Corridor" is getting curved exactly as per the design.
Why is it happening? What is making corridor result differently?
And
What is the solution?
Replies (18)
RobertEVs
Bend angles too tight? Can you put a small radius in your alignment?
aniruddh_ab
I'm using feature lines instead of alignment
aniruddh_ab
Also, I cannot change the layout design.
I have to lay/build the trench on the layout design
RobertEVs
Then try and make a region in the corners and set the frequency very tight for both horizontal and vertical baselines. Or set the entire corridor down to a .25 frequency before making regions and see if that helps. If it does then isolate the tight frequencies to regions in just the corners
RobertEVs
You can see the links have an impossible task of making the corner. A small featureline fillet may necessary. Someone else may know a very easy fix but this is all I can offer
sboon
I'll wager that corridor 1 has a tiny curve at each of those bends, and a corridor station at the midpoint of the curves.
Steve
Expert Elite Alumnus
Joe-Bouza
Ill double down on that. and a tiny MO for curve frequency
Joe Bouza
aniruddh_ab
I tried adding a fillet curve and added corridor station at the midpoint. It resulted in unclean trench corridor.
Any suggestions to get clean trench corridor?
sboon
Go back and look at your original screenshots again.  In 2 the spacing of the corridor leaves enough room so that there are no overlapping sections at the corner.
Steve
aniruddh_ab
I know that there is enough spacing given in the corridor (image 2).
As I have already mentioned earlier, I cannot change the layout design.
Is there any way that I can have a clean trench corridor on the existing layout design?
aniruddh_ab
Please kindly check the 9th message
aniruddh_ab
Beka_Tchigladze
@aniruddh_ab
  • For this type of geometry when your trench is very wide to compare your radiuses corridor is not effective with bends you can split you corridor into different regions and at the places of bends put Grading objects .
  • use offset feature lines and grading tools all along the section, instead of corridor modeling workflow to get clear bends for your trench
  • If you are confident that you want to use corridor and don't want to use grading you have to add curves with necessary radiuses for proper corridor geometry, on you feature lines and you have to sacrifice your angles.
Beka Tchigladze
Road/Highway Technical Designer
AEC Collection/C3D 2025
WIN 11 64 PRO
Predator Helios 18, Intel Core i9 14900HX, 32 GB
NVIDIA RTX 4080, 12 GB
YouTube--->Linkedin
lim.wendy
Hi @aniruddh_ab,
Thanks for posting. Great suggestions and tips by @RobertEVs@sboon@Joe-Bouza & @Beka_Tchigladze
To add, have you tried using the clear corridor bowties feature
If you prefer manual approach, check out these various forum posts:
Alley Corridor
Intersection Design/90 degree turn
I'd like to encourage you to mark your posts as having an accepted solution if the suggestions from our experts help. Accepted solutions get viewed more and help more users find the answer to their problems – so don’t be shy about marking it as a solution!
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
RobertEVs
Split out this region (between thick yellow lines). Add a couple (small yellow) plines. Target them for width within this region. See if that works
aniruddh_ab
I tried this method (by adding "targets" to the subassemblies and targeting it to the trench side lines) but still the trench corridor is not coming out clean.
Beka_Tchigladze
@aniruddh_ab
Hello, there are minimum 3 way above to solve this problem in the comments. Could
you reread them one more time and try to fit on your case? There is not easy one click way to model this type of geometry with corridor
Beka Tchigladze
WIN 11 64 PRO
YouTube--->Linkedin
aniruddh_ab
Found a solution which sort of works at the moment for such a corridor design,
The bend area [within yellow lines] where lines/alignment/feature line meet at the curve/bend point are supposed to be straight [shown as red lines] (should not have any curve).
Before and beyond the "bend area" lines/alignment/featureline can be curved [shown in sky blue color].
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
