Corridor Curve Irregularity
aniruddh_ab
Message 1 of 19
aniruddh_ab
I'm trying to curve the Trench "Corridor" in image 1 but the corridor is getting curved not as per the design/layout.
But in the image 2 the Trench "Corridor" is getting curved exactly as per the design.
Why is it happening? What is making corridor result differently?
And
What is the solution?
Replies (18)
Message 2 of 19
RobertEVs
Bend angles too tight? Can you put a small radius in your alignment?
Message 3 of 19
aniruddh_ab
I'm using feature lines instead of alignment
Message 4 of 19
aniruddh_ab
Also, I cannot change the layout design.
I have to lay/build the trench on the layout design
Message 5 of 19
RobertEVs
Then try and make a region in the corners and set the frequency very tight for both horizontal and vertical baselines. Or set the entire corridor down to a .25 frequency before making regions and see if that helps. If it does then isolate the tight frequencies to regions in just the corners
Message 6 of 19
RobertEVs
You can see the links have an impossible task of making the corner. A small featureline fillet may necessary. Someone else may know a very easy fix but this is all I can offer
Message 7 of 19
sboon
I'll wager that corridor 1 has a tiny curve at each of those bends, and a corridor station at the midpoint of the curves.
Steve
Expert Elite Alumnus
Message 8 of 19
Joe-Bouza
Ill double down on that. and a tiny MO for curve frequency
Joe Bouza
Message 9 of 19
aniruddh_ab
I tried adding a fillet curve and added corridor station at the midpoint. It resulted in unclean trench corridor.
Any suggestions to get clean trench corridor?
Message 10 of 19
sboon
Go back and look at your original screenshots again.  In 2 the spacing of the corridor leaves enough room so that there are no overlapping sections at the corner.
Steve
Message 11 of 19
aniruddh_ab
I know that there is enough spacing given in the corridor (image 2).
As I have already mentioned earlier, I cannot change the layout design.
Is there any way that I can have a clean trench corridor on the existing layout design?
Message 12 of 19
aniruddh_ab
Please kindly check the 9th message
Message 13 of 19
aniruddh_ab
Message 14 of 19
Beka_Tchigladze
@aniruddh_ab
  • For this type of geometry when your trench is very wide to compare your radiuses corridor is not effective with bends you can split you corridor into different regions and at the places of bends put Grading objects .
  • use offset feature lines and grading tools all along the section, instead of corridor modeling workflow to get clear bends for your trench
  • If you are confident that you want to use corridor and don't want to use grading you have to add curves with necessary radiuses for proper corridor geometry, on you feature lines and you have to sacrifice your angles.
Beka Tchigladze
Infrastructure Design Engineer | BIM Automation Developer
Autodesk Developer Network (ADN) Member
Autodesk Certified Professional: Civil 3D & AutoCad
LinkedIn | Autodesk App Store
Message 15 of 19
lim.wendy
Hi @aniruddh_ab,
Thanks for posting. Great suggestions and tips by @RobertEVs, @sboon, @Joe-Bouza & @Beka_Tchigladze.
To add, have you tried using the clear corridor bowties feature?
If you prefer manual approach, check out these various forum posts:
Alley Corridor
Intersection Design/90 degree turn
I'd like to encourage you to mark your posts as having an accepted solution if the suggestions from our experts help. Accepted solutions get viewed more and help more users find the answer to their problems – so don’t be shy about marking it as a solution!
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Message 16 of 19
RobertEVs
Split out this region (between thick yellow lines). Add a couple (small yellow) plines. Target them for width within this region. See if that works
Message 17 of 19
aniruddh_ab
I tried this method (by adding "targets" to the subassemblies and targeting it to the trench side lines) but still the trench corridor is not coming out clean.
Message 18 of 19
Beka_Tchigladze
@aniruddh_ab
Hello, there are minimum 3 way above to solve this problem in the comments. Could
you reread them one more time and try to fit on your case? There is not easy one click way to model this type of geometry with corridor
Beka Tchigladze
Message 19 of 19
aniruddh_ab
Found a solution which sort of works at the moment for such a corridor design,
The bend area [within yellow lines] where lines/alignment/feature line meet at the curve/bend point are supposed to be straight [shown as red lines] (should not have any curve).
Before and beyond the "bend area" lines/alignment/featureline can be curved [shown in sky blue color].
