Corridor Cul-De-Sac Alignment
RobertEVs
Advisor Advisor
RobertEVs
I have seen several videos on Corridor Cul-De-Sac and pretty much have the gist of it. Question is the alignment of the cul de sac. Some videos have the alignment starting at the center of the cul-de-sac while others have the alignment go through the center and tie-in at the far side mid point of the ETW line. Which one is the correct method of designing?
Accepted solutions (3)
Jeff_M
I actually have the alignment extend beyond the sidewalk so the profileview can display the FG profile (sampled from the FG surface). I mask the portion beyond the RP.
RobertEVs
Thanks Jeff.
"RP"? Radius point?
MMcCall402
Extending beyond the radius point (RP) will also allow you to show network pipes and structures in those areas in the profile views.
Mark Mccall
CAD Mangler
VHB - Vanasse Hangen Brustlin, Inc.
Linkedin
CahaLF7RX
I have used both methods.
In Texas, i used the alignment following the curb line.
this allowed creating low points for curb inlets.
(and that was not a problem, as ALL the utilities had their own alignments and plan/profile sheets)
I am now in Washington, and here we extend the alignment through the cul-de-suc and another 50-feet.
we do not have separate plan/profile sheets for all the utilities.
hope this helps.
good luck,
nonbeard13
paudelbikram1234
Are there any videos showing the design process of a cul-de-sac road? I encountered problems while designing a cul-de-sac road. Can someone please provide a step-by-step procedure for building it?
