Corridor Bowties problem
Spent 2 hours to remove Corridor Bowties by using Clear Corridor Bowties command (see attached pics), but did not work, any suggestions? much apprectiated!
Jowenn.Lua
Hi @Anonymous ,
Can you please watch the screencast in the links below first? I believe one of those tricks can help assist you with your issue. If you are still not finding a workaround kindly post your drawing.
Please refer to screencast of:
Message 8
https://forums.autodesk.com/t5/civil-3d-forum/clear-corridor-bowties-command-not-working/td-p/875157...
Message 4
https://forums.autodesk.com/t5/civil-3d-forum/2018-bowtie-cleanup-not-working-for-sas-created-in-sac...
Cheers,
Jowenn
lynn_zhang
Hello @Anonymous ,
Just checking to see if your problem has been solved. Have you tried the above suggestions from @Jowenn.Lua and did they help you fix the issue? If yes, please click on the "Accept as Solution" button in his reply so this helps other users in the community find the solution too. Thanks!
Lynn Zhang
