Coordinates multiplied by factor of 1000
arpenteur
arpenteur
Hello everyone,
I have DWG that the coordinates are in mm. EX.: Y: 5060994386.0m X: 271750688.0m   After scaling the drawing by 0.001, I was able to see the DIM or Di in meters.  But, after exporting points, still having Y: 5060994386.0m X: 271750688.0m
Can't wait to fix this problem.
Roger
copper.chadwick
Autodesk Support
Autodesk Support
@arpenteur ,
Welcome to the Civil 3D forums, this is a really interesting post. I see you are asking about a drawing to which seems to be displaying objects to the tune of Millimeters rather than the intended meters units. I wonder if you wouldn't mind posting the drawing. Preliminarily, I wonder if you were to go and set up the "units" in the drawing settings, in the settings tab if it would get your units displaying as expected. I look forward to your files, if you are not sure about posting them in a public setting, you could always put them into a online file repository and privately send me the download link. Thanks in advance.
Copper Chadwick
Designated Support Specialist
arpenteur
Hi copper,
I attached the drawing as requested.
arpenteur
Hi copper,
What I did to fix the problem, is  that I took 2 knoen locations with x,y, and scaled the drawing by 0.001  After, I moved the drawing to one of the 2 locations.  FYI, I did change the units to meters in the drawing settings.  I also changed some settings: as shown in the attachment.
Is there an easyer way to do all this?
Appreciated for yout time...
copper.chadwick
Autodesk Support
Autodesk Support
@arpenteur ,
I looked at your drawing, I agree that should fix it up. I used the commands Edit drawing settings in the Settings tab of the prospector, and set the units to Meters in there. I also typed in UNITS and set the units to Meters in that location. Finally I suggest using the INSUNITS to set the controls for the units for the conversion/ scaling when importing drawings. Other than doing that on the beginning of everything, the next iteration should be much better now that those things are set up. I think your post is the solution, that others would use to solve their issue if they had the same issue.
This article has peripheral information that might have helped as well.
Objects are scaled when inserted into a drawing in AutoCAD
Please hit the Accept as Solution button if a post fully solves the issue or answers the question.​ Thank you for your participation, your accepting a solution adds value to the post for the community as a whole, and helps other members find answers to their issues.
Copper Chadwick
