Convert Star*Net DAT to FBK Command not working
Message 1 of 17
I'm running Civil 3D 2017 and I have everything installed including the survey extensions (I think) because I can run Survey Link DC under "Home -> Create Ground Data" and can run all the utilities under "Toolspace -> Toolbox -> Miscellaneous Utilities" except that the "Convert Star*Net DAT to FBK" command doesn't work.  Attached is a screen shot of my desktop.  Thanks
Replies (16)
Message 2 of 17
rl_jackson
I would check under report settings and verify that it is installed and/or pointing to the correct location.
Rick Jackson
Survey CAD Technician VI
Message 3 of 17
Pointdump
Paul,
Can you embellish a little on "doesn't work"? Maybe a screen shot or even zip and post your StarNet file?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 4 of 17
AllenJessup
I get the same error:
Unknown command "AECCCONVERTSTARNETDATTOFBK".
Don't know why.
Allen Jessup
CAD Manager - Designer
Message 5 of 17
Pointdump
Allen,
Right-click >> Execute brings up this:
But I've got no data to test.
Dave
Dave Stoll
Las Vegas, Nevada
Message 6 of 17
AllenJessup
Dave,
Not for me. I tried both a Dbl-clk and Rt-clk > execute. I also tried creating a Network first. I get Unknown Command every time.
Allen Jessup
Message 7 of 17
tcorey
This is a known issue for Infrastructure Design Suite Premium and Ultimate users. Fix is here:
https://knowledge.autodesk.com/support/autocad-civil-3d/troubleshooting/caas/sfdcarticles/sfdcarticl...
Dave probably has Civil 3D and not the suite and that's why his works.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 8 of 17
Pointdump: I did put a screenshot in my original post.
tcorey: The new AeccTransportationX.dll file solution is now giving me an error of "Invalid execute file: C:\Program Files\Autodesk\AutoCAD 2017\c3d\AeccTransportationX.dll."  I tried the other solutions here too.  Screenshots attached!
Message 9 of 17
Pointdump
Paul,
Sorry. I saw your command line in the screen shot after I posted.
Dave
Dave Stoll
Las Vegas, Nevada
Message 10 of 17
No problem pointdump.  Appreciate the help anyway!
Attached is another screenshot showing that I put the ProjectSummaryReport in the correct folder as instructed.
Message 11 of 17
tcorey
Sorry, all. I found the article and posted the "solution" before I tested it myself. I am getting the same error. I will create an Autodesk support case. I suspect they posted the wrong DLL on that solution page.
Tim Corey
Redding, CA
Message 12 of 17
tcorey
I have heard back from the Autodesk technical rep. She is escalating the issue. I will follow up as soon as I hear back.
Tim
Tim Corey
Redding, CA
Message 13 of 17
tcorey
Another update. The case was escalated within Technical Support at Autodesk and the representative has recognized the problem. She said they have taken down the link I posted above and the issue has been forwarded to the software engineer for resolution.
I will continue to report results to this thread.
Tim
Tim Corey
Redding, CA
Message 14 of 17
Pointdump
Thank you Tim!
Dave
Dave Stoll
Las Vegas, Nevada
Message 15 of 17
liuja
Under the precondition of using the new AeccTransportationX.dll (659), please try this:
1. Navigate to acad.exe.config (parallel to acad.exe).
2. Add "<loadFromRemoteSources enabled="true" />"  between <runtime> </runtime>tag
3. Save the config file and start C3D.
Let me know if it works. It's doubted as a .Net dll loading security issue.
Message 16 of 17
lim.wendy
Hi all,
Further to Jason's post, for clarity, I've included a screenshot of the string that needs to be added to the "acad.exe.config" file located in C:\Program Files\Autodesk\AutoCAD 2017
Please let us know if it's not working.
Thanks and appreciate all your feedback.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Message 17 of 17
tcorey
Thank you Wendy and liuja for posting this solution. I have tested on my system and it is working correctly.
Tim Corey
Redding, CA
