Is there a setting to have the small line that crosses the contour when labeling so that it is a no plot and does not plot if it is 'longer' and hangs over the contour label?
Solved by Jeff_M. Go to Solution.
No, but you can turn the ContourLabelLines off:
https://forums.autodesk.com/t5/civil-3d-forum/display-contour-label-line/m-p/8659343#M394641
Even when off when a label is selected the grips for the line will display so it can be moved.
