Connect Cul De Sac corridor surface to existing road corridor surface
I have a new proposed main road leading into a subdivision. I have multiple side cul de sac roads I want to connect into the new proposed main road. To get the grading right, how do I get the cul de sac roads to grade into the main road surface and the existing ground surface where it does not overlap the main road surface.
tcorey
Those should be combined into a single Corridor, using Connected Alignments. See this primer from yours truly:
Tim's Civil 3D blog: Corridor Intersection Primer -- Manually Create an Intersection (timsc3dblog.bl...
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Thank you! That is very helpful and easy to follow!
