I'm computing materials and my surfaces are not showing up when I go to put them in.. What step did I miss.... Attached is the file....
Brad
Brad
Solved by tcorey. Go to Solution.
The surfaces are not designated as data sources for the sample lines.
Select any Sample Line on the screen. On the Ribbon, select Sample More Sources. Add your surfaces.
I finally got my surfaces to show in Materials However I am trying to get my cross sections to be regular.. I ran them many times.. Now what they do is pile up as you will see in the photo attached.. I used the same template it worked then I cleared and ran it again many times.. What causes this type of result.. Attached is the file to view..
Brad
Brad
Brad
Brad
New question, start a new thread. That will help future searchers who have the same problem.
sorry
but i have the same problem
i do as u shown exactly
but it does not appear
sorry
Read this over and you can see what you left out.
Bill
Bill
Bill
Bill
Sorry guys.
I don't know how I sent all these extra items.
Bill
Sorry guys.
Bill
Here you go..
Here you go..
Also check your settings for the display by right clicking on the section view.
