Cogo Points
Cogo Points
yogeshnairvarkala
Message 1 of 15
Cogo Points
yogeshnairvarkala
Hi FOlks
         Am having this autocad drawing here i have so many elevations to converted to Cogo points wht am doing is typing one by one as show in the clip is there any other method to click on tht value and directly convert to cogo points?
Can any one hlp me
Replies (14)
Message 2 of 15
Pointdump
Hi Yoks,
Try "Automatic" or "Polyline Vertices - Automatic"
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 3 of 15
yogeshnairvarkala
but i want to enter the Z values tht values am typing manually is there any other ways rather thn typing Z values
Message 4 of 15
AllenJessup
I see text labels. Are they where you're getting the elevations or another source? Are the labels text, mtext, mleaders or what. I'm asking because sometimes you can build a surface from text or blocks and get the elevation from the surface. If you could post your drawing or a part of it with some of the lines and labels in it. That could help us find a method.
Allen Jessup
CAD Manager - Designer
Message 5 of 15
yogeshnairvarkala
Sorry for the delay sir am attaching the drawing
Message 6 of 15
Pointdump
Yoks,
Your lines don't have elevations, so it looks like the way you're doing it is as good as it gets.
Dave
Dave Stoll
Las Vegas, Nevada
Message 7 of 15
AllenJessup
I thought you might be able to use Move Text to Elevation. But there's no way I can find to get the elevation in the point without moving the text to the vertex of the PLine and creating a surface. Then you'd have to assign the piont elevation from the Surface.
Allen Jessup
Message 8 of 15
TerryDotson
Change the attached file extension to .AUF and import it.  Zoom and pan around to inspect the resulting CogoPoints.
Message 9 of 15
yogeshnairvarkala
here X is moved to Y direction and Y is moved to X direction coordinates wnt opposite
Message 10 of 15
TerryDotson
As I mentioned, change the extension to .AUF which is P,N,E,Z,D.
Message 11 of 15
yogeshnairvarkala
voww itwll work how can i do this for a bigger area
Message 12 of 15
TerryDotson
There is no built in tool to do this.  I used a tool in a third party add-on C3DTools, called Convert Leaders to Points.  If you post the full drawing (only the leaders layer) I will run the tool on it and give you the results so you don't have to do all the manual work, or you can request the 45-day full working demo and do it on your end.
Message 13 of 15
yogeshnairvarkala
 How can i get the demo version pls ..tks in advance
Message 14 of 15
AllenJessup
Follow the 3CDTools link in the above post. Scroll to the bottom of the page. There are instructions there on how to get a Demo copy.
Allen Jessup
Message 15 of 15
yogeshnairvarkala
I got the demo copy can u pls send me a gif animation how to do this command pls
