Clipped PDF making drawing extreemly slow
yara_khoury
yara_khoury
Hi All,
I have attached about 10 pdf to a drawing, and it is working great. Once i started clipping the PDF into a small areas, the drawing became very slow. How can i fix that  ?
tcorey
Polygonal clipping is slower than rectangular.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
ianjchap
Hi @yara_khoury,
Happy New Year.
If I start to struggle with speed, my first thought goes to seperating out the information.
Try saving the PDF's to individual DWG's, clipping and Xrefing back into a combined DWG.
Alternatively you could try the PDF import tool and convert the information to DWG format. Results can vary depending on the quality of the PDF and the information in it.
Ian Chapman
If you found this post useful, please Like the post.
If this post helped you successfully solve your problem, then click on the ACCEPT SOLUTION button.
jroot
When I have performance problems in a DWG with attachments I usually blame PDFs. If I'm the one doing the attaching I will always convert the PDF to an image first and seem to have no problems, even with trimming them.
lim.wendy
Hi Yara,
Thank you for submitting your question in our discussion forums. As @ianjchap  mentioned, isolating the problem is often a good first step in troubleshooting performance issues. Here are a few things you can try:
  • Identify the problem PDF: Check which clipped PDF is causing the slowness.
  • Check your clipping shape: If you’re using a custom shape to clip, it might be adding complexity. Polygonal clipping is known to be slower than rectangular clipping, so I recommend using a rectangular crop region and see if that improves performance.
  • Reduce the PDF size: If the PDF file is large, try recreating the PDF at a smaller file size.
If the suggestions helped you, please hit the "Accept Solution" button, as it helps make the solution easier to find for others who might have the same issue. Knowing which topics are solved or not can also help our many users find the questions that still need to be answered. It’s also a great way to say thank you and give recognition to whoever helped you.
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
