Civil 3D Forum
Clipped PDF making drawing extreemly slow
3 ANTWORTEN 3
Nachricht 1 von 4
yara_khoury
108 Aufrufe, 3 Antworten
Hi All,
I have attached about 10 pdf to a drawing, and it is working great. Once i started clipping the PDF into a small areas, the drawing became very slow. How can i fix that  ?
Beschriftungen (2)
3 ANTWORTEN 3
Nachricht 2 von 4
tcorey
als Antwort auf: yara_khoury
Polygonal clipping is slower than rectangular.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Nachricht 3 von 4
ianjchap
Hi @yara_khoury,
Happy New Year.
If I start to struggle with speed, my first thought goes to seperating out the information.
Try saving the PDF's to individual DWG's, clipping and Xrefing back into a combined DWG.
Alternatively you could try the PDF import tool and convert the information to DWG format. Results can vary depending on the quality of the PDF and the information in it.
Ian Chapman
If you found this post useful, please Like the post.
If this post helped you successfully solve your problem, then click on the ACCEPT SOLUTION button.
Nachricht 4 von 4
jroot
When I have performance problems in a DWG with attachments I usually blame PDFs. If I'm the one doing the attaching I will always convert the PDF to an image first and seem to have no problems, even with trimming them.
Rail Community
