After using Autodesk recommendations for a clean install, remove programs, remove files and remove registry edits I can not delete the file
C:\Program FIles\Common FIles\Autodesk Shared\acsigncore16.dll
Can someone explain how this file is still in use if all Autodesk files and references were removed?
John Mayo
Solved by AllenJessup. Go to Solution.
I'm having a similar problem (can't delete shared folder because file is in use) and am working with support. I'll post a solution if I find one.
Possibly
http://forums.autodesk.com/t5/AutoCAD-2004-2005-Archive/AcSignCore16-dll/td-p/16871
or
Allen
Allen Jessup
CAD Manager - Designer
Wow. I installed the Cleanup utility and removed the Autodesk entries that were stuck. Rebooted and Still no luck with the delete. I then renamed the folder (which I found real odd that I could given it's contents were in use), rebooted and was able to delete the file. Now I can run setup without it telling me the software I removed is installed. 😮
Thanks Allen.
John Mayo
Thank You...
Worked for me too... rename the folder and reboot... then it allowed me to delete the folder.
Down load Iobit uninstaller, that beast srubs
Joe Bouza
