Civil 3D Forum
civil3D problem
5 REPLIES 5
ao.casaus
190 Views, 5 Replies
civil3D problem
using 2019 Civil3D i saved and closed a drawing when i opened drawing several times multiple polylines added on top of line work. only way i noticed is when i did print preview lines were alot darker than supposed to be. went back into model clicked first line there were 3 polyline on top of line work in different layer type. I have rebooted system twice log completly logged out. everytime i goback in its same issue but mostley in same place  but everytime there issame location and several new locationscivil3d pic.jpg
Tags (1)
5 REPLIES 5
pendean
in reply to: ao.casaus
rebooting your computer is not going to clear three elements sitting on top of each other: try ERASE command perhaps?
ao.casaus
in reply to: pendean
erase delete works excellent just restarted program after using overkill erasing duplicates than i saved closed went to lunch got back reopened to same problem. polylines on top of line work. erase is probably first command we all learned trying to see what causing this problem every time file opens with new polylines .
Pointdump
Hi @ao.casaus,
I've never heard of this happening, but then every day is a new day. Do you have any 3rd party programs attached, or special LISP's? Is it just this drawing, or all drawings? What version Civil 3D? Do you have all updates, including AutoCAD and Map 3D?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
ao.casaus
in reply to: Pointdump
i could only create it on one other file opened 10-12 files. No 3rd party
programs LISP, only ones used on this were DLB and KO. what i noticed is
the only time it duplicates is on top of square rectangle objects. When i
started this file, the only warning message i received was this was saved
with an older file type. So I went back and saved it as a 2010 DWG but
still had the same problem.
rl_jackson
Ghost Parcels perhaps? There's a command that removes those, I believe its PHANTOMPARCEL or something like that.
Rick Jackson
Survey CAD Technician VI
Rail Community
