using 2019 Civil3D i saved and closed a drawing when i opened drawing several times multiple polylines added on top of line work. only way i noticed is when i did print preview lines were alot darker than supposed to be. went back into model clicked first line there were 3 polyline on top of line work in different layer type. I have rebooted system twice log completly logged out. everytime i goback in its same issue but mostley in same place but everytime there issame location and several new locations
erase delete works excellent just restarted program after using overkill erasing duplicates than i saved closed went to lunch got back reopened to same problem. polylines on top of line work. erase is probably first command we all learned trying to see what causing this problem every time file opens with new polylines .
Hi @ao.casaus,
I've never heard of this happening, but then every day is a new day. Do you have any 3rd party programs attached, or special LISP's? Is it just this drawing, or all drawings? What version Civil 3D? Do you have all updates, including AutoCAD and Map 3D?
Dave
Dave Stoll
Las Vegas, Nevada
Ghost Parcels perhaps? There's a command that removes those, I believe its PHANTOMPARCEL or something like that.
Rick Jackson
Survey CAD Technician VI
