Hi Everyone,
Can someone give me a bit of guidance on how to make transition on this spillway channel model that I’m trying to create.
Here is a corridor that I created having a channel width of 20m and daylight batters of 1V:1.5H to existing ground.
I used a very basic assembly for this corridor from the sub-assemblies found in the Generic Civil Metric preloaded in Civil3d:
Now, I’m required to revise the model to have 1V:6H batters ONLY on the part where there is an existing road (Roughly from Chainage 70 to 100)
Any input will be very much appreciated. Thanks. 😃
Hi Everyone,
Solved by Jeew-m. Go to Solution.
Solved by Jowennl. Go to Solution.
Hi @Anonymous ,
If you are doing this via corridor, you can get the subassembly you need to do the transition in ANZ Country kit.
See attached image as a guide.
See this <AU Class> - by my friend Andrew as he explained it very well in 23:27 onwards. (Exercise 2)
Cheers,
Jowenn
Jowenn Lua | Retired Account See My New Profile Here
AU 2023 CES600726 – Getting Started with Generative Design in Civil 3D: A Beginner’s Guide
AU 2020 CES473668 – Supercharge Your Dynamo Graph with Civil 3D Toolkit
AU 2019 CES319333 – Dynamo in Civil 3D Introduction Unlocking the mystery of scripting
AU 2018 CI225967 – Using Automation in Civil 3D for Construction Documentation and Exports
AU 2017 CI123653 – AutoCAD Civil 3D and Subassembly Composer— Real-World-Practice Tips and Tricks
Hi @Anonymous ,
Cheers,
Jowenn
Hope this will also help you.
