Civil 3D UKIE 2025.1 Plot Volume Report
neilyj666
Mentor Mentor
neilyj666
Any one tried the plot volume report in the toolbox?
I get a config error although the Report does run
This seems to affect back to 2024 and 2023 both of which have worked with no issues and I get an html file which I copy to Excel (the native Excel export has never worked for several releases now) and run some VBA to format how I need it but this is now broken and doesn't tabulate the data as I require -perhaps as a result of the config file error
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Accepted solutions (3)
Jeff_M
I got that error earlier. I then tried to change the report settings which came up with a blank form. I found this file was missing from C:\Users\jeffm\AppData\Local\Autodesk\LandXML Reporting
I copied the stock one from the Support folder and all was well.
neilyj666
@Jeff_M  same here...where is the Support folder located??
Jeff_M
@neilyj666 mine was in the same folder as shown in my screenshot. It appears yours is not... If you have access to the installer files for Civil 3d 2025, you could copy the support folder from there. This is where I saved the installer for 2025:
D:\Autodesk\2025\Civil 3D 2025 - English - (EN)\x64\en-US\c3dps\PF\Root\PF32\Autodesk\LandXML Reporting 8\Support
neilyj666
@Jeff_M after a long search I found them...
..now to see if they work.
What is more disturbing is why they weren't installed in the first place
neilyj666
Big shout out to @Jeff_M who has come to the rescue yet again...😁
