Civil 3D Forum
Civil 3D Table Settings (ROW HEIGHT)
99 REPLIES 99
Message 1 of 100
17049 Views, 99 Replies
Hey Everybody I searched all these boards and found a couple posts on this but no answers. Is there a way to change the row height in Civil 3D Created Tables (What I'm working with is Parcel Line and Curve Tables). I don't see any options in the styles or table properties menus and changing it in the general autocad tablestyles menu does nothing. Thanks for the help!
Matt Moore
Racey Engineering, PLLC
C3D SP2
Tags (1)
99 REPLIES 99
Message 81 of 100
Jaimee.Hansen
your answer only works for non-dynamic tables, or for tables you manually type into.
this question specifically stated its for civil 3d created tables (example: click alignment > create line/curve tables) and then its a table that civil 3d autofilled information for.
i too am trying to adjust row height for a pipe network and it's not giving me the option anywhere at all.
Message 82 of 100
Jaimee.Hansen
i am super confused with all the replies. they link to an ideastation however that ideastation does not seem to address the initial question. i just wanna change row height. where is the answer? row width is easy! howcome we get to control row width and not row height? see screenshot. i am having trouble telling if any of the comments/replies actually are the answer to the question.
Message 83 of 100
jmayo-EE
in reply to: Jaimee.Hansen
There is no way in the current product to change row height in Civil 3D tables. The links to the Idea Station is a separate forum that provides Autodesk with feedback for possible new features. Folks on this post are hoping everyone votes for this idea (adjusting Civil 3D table row height) becomes a new feature.
John
John Mayo
Message 84 of 100
cfranklin4LVF4
in reply to: lim.wendy
@lim.wendy I hope you're having a great start to 2023!
We're coming up on a year since the last update, have you heard anything from your team members regarding this issue? Any plans for next release?
Thanks! 🙂
Message 85 of 100
tazeman
After years of posting and starting 2023 we were hoping that this rather minor change could be made in the latest update. However it appears that we still have not been able to affect change. To my knowledge there are only complicated time consuming work arounds. We still cant change the height of line, curve, or coordinate tables.
Message 86 of 100
tazeman
 @lim.wendy - What happened to this being addressed in the upcoming version? Quote on 1-13-2022 .... "On this issue, yes, we have good news that this feature will be enhanced in the upcoming version. "  Who is accountable for following through with this?
Message 87 of 100
Incognito_Cube
in reply to: tazeman
Absolutely correct. Replies 62 (my own) and 63 (@Anonymous) are the work-a-rounds that I have been using. My own more often than not only because I've been doing it so long it doesn't take all that much time for me, but I've been considering trying out the export option to bring it back into an editable table more than my own method. Either way, both options remove the ability to display the dynamic results of the tables and require the technician to keep track of the changes one way or another to update the static tables.
I'm not a programmer or developer by any means, so I won't pretend to have any insight as to how "minor" of an update this would be for the AutoDesk team... BUT... If this was actively being worked on, I feel like this would have been taken care of long ago.
At any rate, it's up to the AutoDesk team to show how much they care/listen to feedback. At this point in time, we have 87 replies to this thread, and a whopping 2 from AutoDesk. There's not much else that needs to be said there.
Edit: Words are hard.
Message 88 of 100
tazeman
in reply to: Incognito_Cube
Love the office and Jim.... but i was thinking more like Dwight. Autodesk really cares about this.....
Message 89 of 100
JOKO_
Just downloaded Civil3D 2024.  Still no way to edit row height that I can see.  Am I missing it?
Message 90 of 100
Eduardo.Soethe
in reply to: JOKO_
It is so frustrating!!!
Eduardo Soethe Cursino
Civil Eng. | BIM Specialist
Soethe Cursino Consultoria | BIM for Infrastructure | LinkedIn
Autodesk Certified BIM Specialist: Road and Highways Solution
AutoCAD Civil 3D Certified Professional
__________________________________________________________________________
Se a resposta resolveu o seu problema, clique em Aceitar como Solução isso ajuda os outros usuários a encontrar rapidamente uma reposta e Kudos de gostou.
Autodesk Community
Message 91 of 100
DBreisch
Sad, this thread started on ‎01-18-2006 04:47 PM and there is still no improvement. Thanks AutoDesk, really out there listening to your users!
Message 92 of 100
cfranklinKPZDH
in reply to: DBreisch
This thread has been around longer than most marriages.
Message 93 of 100
cody.faltin
With the advent of project explorer I doubt we will ever see improvement here, which would be fine if you could set your project explorer table settings to use index colors rather than rgb values.  Only way to make a project explorer table print properly is to either change all the colors after creation, or set the true color to black, which doesn't work when you use dark mode.
Message 94 of 100
Incognito_Cube
TBH at this point I hope it doesn't get fixed. This is thread is the most stable thing in my life, I can always count on it coming back around once or twice a year.
/s
Message 95 of 100
tazeman
Greetings bloated table users. The politically correct thing would be simply to accept these overweight tables, for their beauty, and move on. However, the creators of the data, sometimes need a skinny version of the table to be able to convey the data without causing additional sheets to be created. Autodesk this is now a green initiative; you clearly do not love the visually concise presentation of data, or the planet (in that we need to create additional sheets to convey the same data). Put your fat tables on a diet, save the planet, quit ruining my life.
This was the latest from Autodesk....  4-22 - "On this issue, yes, we have good news that this feature will be enhanced in the upcoming version". WHERE PRAY DO WE FIND THIS IN 2024??????????? NOPE! How much code time could this possibly take? You already have the code; you just need to move it to the annotation table window and call it good. Way to follow through on a promise. Till next year... or version....
Message 96 of 100
rgrainer
At AutoDesk, one of our main priorities is listening to our customer.
https://imgur.com/gallery/sWsCp1p
(I don't how to embed like you did)
Message 97 of 100
lim.wendy
Dear all,
Upon further investigation, I have realized that the enhancement I previously mentioned pertains to Project Explorer, which indeed allows for user-defined row heights in the tables it generates. I apologize for any confusion caused by my prior post.
I want to express my gratitude for all the feedback and discussions that have occurred here. Your input is invaluable in our ongoing efforts to enhance the software and effectively address user concerns.
I am dedicated to ensuring that your concerns are heard and acted upon. Consequently, I have resubmitted this matter to our development team for a fresh evaluation. Please be assured that your voices are pivotal in driving positive changes in Civil 3D.
Should you have any further questions, suggestions, or concerns, please do not hesitate to share them here. We are here to support you and ensure that your experience with Civil 3D remains as seamless as possible.
I appreciate your understanding and continued active participation in our community.
@TimYarris
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Message 98 of 100
tazeman
No disrespect to you personally here. Talk is cheap, it's a shame your software is not. We are on the hook each year for thousands of dollars just to have the latest and greatest. The program should address and fill the needs of the subscribers especially when those needs are manifest over many years as this one has. Each year (or sooner) you all march out new versions of expensive software full of nonsense "improvements" that only 5% of us truly need/use. When someone presents a legit need and seemingly a simple one at that it is wholly ignored. Since you only now claim to understand the issues after 17 years of complaints, I must ask, was this now years old complaint ambiguous? Why are you only now getting this issue in a Eurika moment?? Is this really the best you can do? Sorry it's past time to get this done, instead of the perfunctory word salad that really does nothing for anyone. I get it, you're not a code writer... that is someone else's job. Get this fixed and at that point you will have earned some thanks, which I'm sure all on this thread will readily give. I'll be the first to wave the Autodesk flag and buy the t-shirt...until then, this answer rings pretty hollow. I would like to know what will you do personally to make sure that whoever is in charge of this, understands the problem and is highly motivated to fix it in the next update? Or will it wither in the suggestion box, in the corner of the room where the Clovis or Marcell Ledbetter code writers, check it every three years? Or in this case 17 years, since 2006.........I mean seriously......🙄
Message 99 of 100
Incognito_Cube
@tazeman wrote:
No disrespect to you personally here. We are on the hook each year for thousands of dollars just to have the latest and greatestGet this fixed and at that point you will have earned some thanks, which I'm sure all on this thread will readily give.
Well said Taze. I know I have certainly injected my own sarcasm and frustration into this thread a couple times over the last few years, but it is true. Underneath said sarcasm and, mainly, the frustration there is the driving desire for this issue to actually be addressed shared by all of us here. What appears to be quite honestly a simple fix (relatively) to a major oversight has been either ignored, or apparently misunderstood for all this time, which does add more to the frustration. I am happy we got another reply, but until we see substance the tone of this thread will likely not change, nor should it. Once we see action on Autodesk's part, I will be right there with you and hastily give my sincere thanks and gratitude.
Largely I just hope that the next issue that is brought up doesn't get this same treatment after all the tens or hundreds of thousands of dollars that has been sunk into this program over the years by us and our companies who rely on this program to keep the construction and design industry running. In my opinion AutoCAD is the best program on the market for my needs, and if it wasn't the only realistic option I have I would have jumped ship long ago. Hopefully they will start acting like developers of the best program on the market here on out.
Message 100 of 100
Cadguru42
This was a part of my most requested Idea of C3D.
https://forums.autodesk.com/t5/civil-3d-ideas/editable-c3d-tables/idi-p/5573857
Autodesk has relied upon purchasing a 3rd party software, Project Explorer, to address this issue. The Idea that Autodesk marked as implemented wasn't implemented at all. AutoCAD tables and MTEXT cannot read C3D object data, which is what the Idea requested.
Project Explorer only partially implemented the Idea in the ability to create an AutoCAD table that can reference some object data. If the table is manually edited at all then when the table needs updating you lose everything you did.
But at least row heights can be changed after 22 years. 🙄
C3D 2022-2025
Windows 11
32GB RAM
Rail Community
