Civil 3D Forum
Civil 3D Stops Recognizing Keyboard Input.
9 REPLIES 9
Message 1 of 10
JustinGG5N9H
347 Views, 9 Replies
Hey Everyone,
I have been dealing with a minor annoyance in Civil 3D that accurse once or twice a month. Without warning, Civil 3D will stop recognizing keyboard input and shorthand commands, other then basic windows commands (ex: Ctrl+Shift+S for Save As). Every time it does happen, I have to restart Civil 3D to fix it.
Does anyone know why this happens, and if there is a way to fix the issue? Like I mentioned, it is a minor annoyance, but it would be nice to eliminate the issue if possible.
Thank you for your time and assistance with this in advance.
Labels (2)
9 REPLIES 9
Message 2 of 10
MMcCall402
in reply to: JustinGG5N9H
If you have multiple drawings open, it could be that the command line in one of the other drawings has become the active command line.  Switching drawings and then back again usually works for me.
Mark Mccall
CAD Mangler
Hammer Land Engineering
Linkedin
Message 3 of 10
Joe-Bouza
LEVELOFDETAIL = OFF
Joe Bouza
Message 4 of 10
neilyj666
in reply to: MMcCall402
@MMcCall402 happened to me in 2024 today - very irritating and I wish they'd find a fix for it.
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 5 of 10
Joe-Bouza
LEVELOFDETAILOFF fixes it for me. Not the same for you?
Joe Bouza
Message 6 of 10
I set LEVELOFDETAILOFF in each drawing after it loads, and I haven't had anybody report this issue to me yet.
Thanks.
I spend time on this forum because I enjoy Civil 3d and getting your likes.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Civil 3d to Street View: https://youtu.be/8Ima00-vLQA
Vote for My Idea:
https://forums.autodesk.com/t5/civil-3d-ideas/favorite-coordinate-zones/idi-p/12790928
Message 7 of 10
neilyj666
in reply to: Joe-Bouza
LEVELOFDETAIL is OFF by default for me and yet it still happened...!!!
Message 8 of 10
JustinGG5N9H
After seeing your post, i have set levelofdetail to off. I will give that a try for now. If it doesn't work, then I will try something new.
Message 9 of 10
Joe-Bouza
in reply to: neilyj666
That's annoying.  ... I'm struggling the a properties palette the  size of a postage stamp and it wont resize
Joe Bouza
Message 10 of 10
I'm having the same issue (and others... screen goes blank, can't select). It becomes more frequent in certain dwgs. I'm working with our reseller to troubleshoot it but they're at a loss.
Tried working off one monitor, alternative graphics drivers, running updates, wblocking dwgs and auditing etc. with no luck.
Civil 3D 2022.2.5
Win 10 pro
Intel i7 2.50 GHz
RTX A2000
Rail Community
