Civil 3D Forum
Civil 3D Points with blocks
14 REPLIES 14
Message 1 of 15
654work
836 Views, 14 Replies
We have a client that want a flattened survey. Points are to be blocks symbols (not a marker using an AutoCAD Block symbol). Is there a way to have blocks inserted when processing the points similar to the way Land Desktop did?
Civil 3D 2018, latest updates
WIN 10
14 REPLIES 14
Message 2 of 15
tcorey
in reply to: 654work
This is easy to do with LISP...
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 15
654work
in reply to: tcorey
Thank you for the rely.  I was hoping for some toggle/setup in C3D.  I don't have time to look at this due to other projects.  I guess I'll let the staff in our other office deal with this (flatten dwg, and show points as exploded symbols).  Will look into it in the future.
Message 4 of 15
caddie99
you can't dumb down point styles with blocks into exact replicas, there is some rotation and scale problems with them when using 'export to autocad'
I asked  DOTSOFT if they had something that could do this and they said it could not be done
Message 5 of 15
Jeff_M
The Sincpac-C3D add-on package has the MarkerExtract tool to do this.
Message 6 of 15
654work
in reply to: caddie99
Correct, but for now it's the best option we have.
Message 7 of 15
654work
in reply to: Jeff_M
Jeff, thanks for the information.  I'll suggest we take a look at this.  It might do for the short term.  I'm uncertain how many projects we will do for this client, but we think it will be a lot.
Message 8 of 15
AllenJessup
It's not perfect and will not include marker blocks. But this will create blocks from the points.
Allen Jessup
CAD Manager - Designer
Message 9 of 15
samir_rezk
Hi @654work
perhaps using the “exportcivil3ddrawing” command available on the output tab will do the trick considering that your client is looked for a flattened survey.
on a separate note, it has been my experience that engineers want to flatten cogo points and survey figures so they don’t snap to there respective elevations, so I’d like to mention that you can apply a flatten to a 0 elevation in the style of these objects! That will maintain the data integrity but visually it will be at 0!
hope this helps,
Samir Rezk
Technical Support Specialist
Message 10 of 15
654work
in reply to: samir_rezk
Thank you for the reply. We used the flatten last submittal. Unfortunately this makes each symbol an individual block, so trees and other symbols don’t have one block but many.  Yes everything can have a 0 elevation as mentioned. The client does not want any Civil 3D information, so no survey figure lines, points...
Message 11 of 15
rl_jackson
Sound to me like your going to have to do several operations to accommodate your client. First explode the point data do that it's dumbed down. Then explode and flatten all your figures and then finally export the entire mess so that it can be opened in plan AutoCAD. HTH
Rick Jackson
Survey CAD Technician VI
Message 12 of 15
caddie99
explode all   (x7)  will dumb down the file
then use
'export to autocad '
Message 13 of 15
654work
Correct. That is what I did last submittal. I was just hoping to extract the pints into the original blocks defined in the point styles. I’ll look into Sincpac and possibly writing a lisp routine for future submittals.
thanks for the reply’s. That is why I like this form.
Message 14 of 15
lynn_zhang
Hi @654work
Thanks for posting and glad to see you got so many replies trying to help you! That's the purpose of our forums 🙂 Let us know if the suggestions from our experts solve your problem or if you still need help!
Lynn Zhang
Message 15 of 15
m_kingdon
Not entirely sure of the issue, but you could enter the block editor and insert a point in the block, next save and explode all the blocks which will leave lines and a point in the exact position?
Mike Kingdon
Civil 3D Zealot
Rail Community
