Civil 3D Forum
Civil 3D fatal error
6 REPLIES 6
6578 Views, 6 Replies
fatal error unhandled e06d7363h exception at 64181f28h
@BushW has edited your subject line for clarity: fatal error unhandled e06d7363h exception at 64181f28h
6 REPLIES 6
hencoop
hencoop
Try AUDIT.  If that does not work,
then try RECOVER.  If that does not work,
then try WBLOCK (if you can wblock the things you need... this may require two or more WBLOCK operations: one for ModelSpace and one for each Paperspace, then reassemble the parts).
I hope this helps you.
AutoCAD User since 1989. Civil Engineering Professional since 1983
Product Ver.: 13.6.1781.0 Civil 3D 2024.3 Update
Built On:        U.152.0.0 AutoCAD 2024.1.2
                        27.0.37.14 Autodesk AutoCAD Map 3D 2024.0.1
                        8.6.52.0 AutoCAD Architecture 2024
BushW
BushW
Hello @Anonymous
Sorry to hear that you are having this issue but, we need more information from you in order to help solve your problem.
What AutoCAD product and version are you using?
Did this happen on startup or when using a particular command?
Is this happening to all your drawings or just one and what type of objects reside in your drawing?
Any information you can provide will significantly help in finding a solution to your issue. Thanks you.
Wendell Bush
Civil Infrastructure Technical Support Specialist
Hello @Anonymous
Wendell Bush
in reply to: BushW
im using autocad LT 2018. after working 10 or 20 min it shows error or when i save file then it show error
BushW
BushW
Hello @Anonymous
Have you had the opportunity to try auditing and recovering drawing as @hencoop suggested? Here is AKN article on How to repair corrupt AutoCAD files which will help you on cleaning and repair a drawing file that has been damaged or corrupt.
Please try the suggestions made in the articles provided and post back with any questions.
Please select the ‘Accept as Solution’ button if my post solves your issue or answers your question so, other Community members may benefit and thank you for doing so, and I'm here to help.
Wendell Bush
Hello @Anonymous
Wendell Bush
I already contact Autocad support team by phone and they told me to update autocad hotfix 5.1.5 from autodesk desktop App. and i updated all from here and my problem solved.
thanks To all
ISTIAK
thanks To all
ISTIAK
Buenos días, como resolviste el problema? estoy teniendo el mismo error. Por favor me podrías indicar que es hotfix y cómo lo actualizo?
Rail Community
