Civil 3D crashes when I type insert.
bwilhoite5D4UA
Message 1 of 9
bwilhoite5D4UA
I am running Civil 3D 2025 and i have an issue trying to insert blocks. I system crashes every time. This is the error message I get. Civil3D Error.jpg
Replies (8)
Message 2 of 9
brian.strandberg
I would try logging onto your computer with another account.  If it works then its probably a corrupt windows profile.  See here for more information  "All of the possible directories for storing temporary files either do not exist or are readonly" wh...
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
Message 3 of 9
bwilhoite5D4UA
Logged in with another account and same problem and we have the same issue on at least 2 computers now. Can I do a Repair or do I need to reinstall Program?
Message 4 of 9
AllenJessup
Make sure these are correct, available and not on a drive that is full.
Allen Jessup
CAD Manager - Designer
Message 5 of 9
AllenJessup
If you're pathed to a network drive. The problem may lie there.
Allen Jessup
Message 6 of 9
bwilhoite5D4UA
I think We may have found a problem. We have another program that is blocking a certain file from being created. Our IT people are working on it but I will check these directories as well. Thank you for your help
Message 7 of 9
bwilhoite5D4UA
Another problem maybe the Civil 3D version. our one guy is using Civil 3d 23 and not having issues. Only the 2 with Civil 3d 25 are having problems
Message 8 of 9
pendean
Community Legend
Community Legend
Your screenshot indicates an IT/login limitation issue, not much else.
Have you engaged your IT person yet? reset your 2025s yet? Your two 2025 users have something going on unique to you two (bad migrations perhaps).
Message 9 of 9
Cadguru42
Do you think it's related to the folder the thumbnails from the insert pallet use? We've had issues before where the read/write lag when pointing to a network causes strange errors when AutoCAD/C3D tries to create the tiny PNG thumbnails and cannot access it as fast as ACAD wants. Another time I've had an issue was when a drawing had a very large block definition in it and the Insert pallet would crash C3D.
C3D 2024-2026
Windows 11
32GB RAM
