Civil 3D 2026 with AutoCAD 2026.0.1 - No Map in ribbon
neilyj666
Mentor Mentor
Message 1 of 22
neilyj666
Interesting and very annoying issue - just installed C3D 2026 and no option for showing the maps which is present in 2025....
.....and C3D 2026 includes the AutoCAD 2026.0.1 patch
This is using the British English version of Civil 3D 2026 (eng) rather than the American English (enu) - so perhaps a pathing issue?
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Replies (21)
Message 2 of 22
ChrisRS
It is probably something else, but have you assigned a coordinate system in Drawing Settings, Unit and Zone?
In USA version Civil 3D 2025 and 2026 the Geolocation tab does not appear until Unit and Zone are set.
Christopher Stevens
Message 3 of 22
neilyj666
This is all set in the template - I wouldn't have the Geolocation Tab if they weren't set. I'll create a Support Case if I can work out how to do it; can see all the the cases but not how to create a new one...!!!!!
Message 4 of 22
ChrisRS
Oops! I misread your photo on my phone.2026 is working for me (USA)
Christopher Stevens
Message 5 of 22
Pointdump
Hi Neil,
"This is all set in the template..."
Have you tried starting with an Out-of-the-Box template?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 6 of 22
neilyj666
Hi Dave
The OOTB Metric template is based on the NCS Layers which isn't used in the UK but I tried and the used GEOCSASSIGN and still no maps - I'm going to raise a support ticket in the first instance and may also uninstall 2026 and reinstall the first release version and then add the Vanilla CAD patch 2026.0.1
Message 7 of 22
neilyj666
I did a clean uninstall and reinstall and installed the first Civil (without the AutoCAD 2026.0.1 patch) and the Maps appeared but only the ESRI ones - no Bing at all. I then installed the 2026.0.1 AutoCAD patch and the Maps had again disappeared.....so it's another uninstall and reinstall...😡
Message 8 of 22
ChrisRS
This was a duplicate. Please remove.
I cannot report my own post to ask for removal, so feel free to report this.
Christopher Stevens
Message 9 of 22
ChrisRS
As of 10:00 am Arizona Time, 2025-04-22, I have been able to access Bing imagery from both Civil 3D 2936 Imperial and Metric (USA).
I inquired during this morning's "What's New in Civil 3D 2026" webinar and was told "It was just fixed (or added back)." This was in the Q&A windows, not verbal.
I do not know if this is global or if it will take time to roll out.
Hopefully you will have Bing back soon.
Christopher Stevens
Message 10 of 22
neilyj666
@ChrisRS thanks for the info - hopefully it will get sorted out (even if Bing maps are only for a short time)
This time of year is always the time to look forward to finding out what Autodesk have broken in the new release that was working flawlessly in the previous version....😒
Message 11 of 22
neilyj666
Autodesk have posted a "solution" to this issue https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Bing-Maps-are-not-... but as I have demonstrated it doesn't work
Message 12 of 22
cwr001
Until the release of 20XX.1 (or .2 for that matter), early adopters are just unpaid beta-testers. 🙂
Message 13 of 22
neilyj666
Very true
Message 14 of 22
ChrisRS
6:00 am Arizona Time, 2015-04-23 (corrected date type)
For information and trouble shooting. (I am not trying to be argumentative,)
Civil 3D 2026 Metric, (USA)
I do not know is this is an appropriate zone, but it is one that enables the Geolocation tab.
(I cannot be sure, but yesterday when I first tested this, I had not installed the AutoCAD fix and I believe it worked for me.)
The Geolocation tab is a core AutoCAD feature. Have you tried this in AutoCAD vs Civil 3D?
You said: "... hopefully it will get sorted out (even if Bing maps are only for a short time)"
Searching elsewhere I find that, at least for enterprise, Microsoft suggests Azure Maps over Bing Maps.
Bing maps definitely is or is not being phased-out/deprecated. You will feel right at home with Microsoft's version of transparency.
The year 2018 is mentioned, but I would take that as a kind of, sort of, maybe thing.
The Forum is in flux again. The reply text editor shows 6 lines and is no longer expandable.
It was a true joy to compose this response. I disavow any formatting faux pas. You are just not modern enough.
Christopher Stevens
Message 15 of 22
neilyj666
ESRI maps are working (no Bing maps) without the AutoCAD 2026.0.1 "fix" and I'm reluctant to apply this fix, as if it all goes wrong (again), there is no uninstall and it is a total removal of Civil 3D 2026 and reinstall.
I have raised a Support Request but no response thus far
Message 16 of 22
neilyj666
Message 17 of 22
neilyj666
One of my colleagues inadvertently installed Civil 3D 2026 US English version and the Maps (Bing and ESRI) worked as expected. My conclusion is therefore that there is something wrong with the current build of the British English Version of Civil 3D
Message 18 of 22
RobertEVs
Use your AI assistant. I have had someone directly from Autodesk contact me through this.
Message 19 of 22
neilyj666
@RobertEVs never seen this before (or if I have I must have turned it off straight away)...!!! How have you got it to appear next to the Help icon - CUI tweak?
Message 20 of 22
neilyj666
Maps issue in C3D 2026 British English confirmed by Autodesk Support staff - fix awaited
