Civil 3d 2024.4 update isn't showing in Autodesk Access.
brian.strandberg
Advisor Advisor
Message 1 of 8
brian.strandberg
Civil 3d 2024.4 update isn't showing in Autodesk Access.  I can install this from manage.autodesk.com, but then I need to use my Admin Credentials, I don't through access.
I also posted in Installation & Licensing.  https://forums.autodesk.com/t5/installation-licensing/access-available-updates-list-refresh/td-p/127...
Thanks 🙂
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
Replies (7)
Message 2 of 8
brian.strandberg
It is now.
Message 3 of 8
sirjoelsph
Hey Brian,
I'm curious how your account and permissions are set up if you don't have to use admin credentials for updates through Autodesk Access.  I didn't know that was a thing that was possible.  I have to use my admin credentials for any update regardless of how I install it.
-JOEL
Message 4 of 8
brian.strandberg
We recently started doing this.  There is a registry key that enables this function.  You can read about it here: https://help.autodesk.com/view/ACCESS/ENU/?guid=GUID-C369BE4F-F0D9-4D48-AFE6-004E37977F45
We used group policy to add the AllowSystemContextInstall registry key.  However I also looked at how to do this with batch file (this typically would have to be run with admin credentials).  I can share that with you here.  You will need to update the pathing for your system.
The nice thing is once we applied the AllowSystemContextInstall registry key, Access updated on its own, so we didn't need to do that.  Big time saver for me, and I'm all about saving time.  Access needs to be version 2.6 or higher I believe for this to work.
Please reach out if I can help.
Message 5 of 8
sirjoelsph
Lots of great information there Brian.  Thanks!
-JOEL
Message 6 of 8
neilyj666
@brian.strandberg How does Access get updated?
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 7 of 8
brian.strandberg
You can download a new version here: Autodesk Access | Formerly Autodesk Desktop App | Autodesk  (download button towards the top). What I found is once I applied the AllowSystemContextInstall registry key, access updated on its own.
Message 8 of 8
brian.strandberg
@neilyj666, You can check what version is installed from the command line via this mini Powershell command.  I run this from our IT software to check if people are getting the update.
powershell -command "Get-Item -Path Registry::HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\ODIS
It will return this (or similar).  From this I can tell this user can install their own updates.  (They have access 2.6+ and have the allowsystemcontextinstall registry key)
