Civil 3D 2015-entities are put on different layers by the program at a whim.
as I am working in the C3D program certain entities get moved to different layers at whim.  Surfaces and pipe labels seem to be the entities most often effected.  Is there a fix for this issue?
Greg
Welcome to the forums!!
my first guess woutd be - are you using multiple lable styles for the pipes?  if so check the layers each style uses.  you may just need to modify the styles.
and i would guess the same for the surfaces - changes from "Existing contours" to  "1 and 5 Foot" or something similar.
keep an eye here in the forums - there is a whole lot of information on multiple subjects.
and try to remain calm and think  " i get paid by the hour . . . ."   (YES, i know you still have to produce drawings)
best of luck
nonbeard13
