Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
CHANGE ALL STANDARD TEXT STYLE TO CUSTOM IN ONE GO
kalpeshpote
Message 1 of 14
kalpeshpote
I want to change all standard text style which is in all label's styles, multileader, nearly every text in civil 3d has standard text style which I want to change to one custom style for my template.
Replies (13)
Message 2 of 14
ianjchap
Hi @kalpeshpote,
Identify what Text style name is being used by default in most of your styles, and make any changes in that text style directly.
Ian Chapman
If you found this post useful, please Like the post.
If this post helped you successfully solve your problem, then click on the ACCEPT SOLUTION button.
Message 3 of 14
kalpeshpote
Hello
the text style in most styles is STANDARD; can you tell how I can change its name to another.
Message 4 of 14
ianjchap
Can't you just make any changes inside that text style?
Or are you looking to get this into a Template for all other drawings?
Ian Chapman
Message 5 of 14
kalpeshpote
YES I AM TRYING FOR  A TEMPLATE
Message 6 of 14
ianjchap
You can rename it to something else, then make changes to it. This will also update the Style name in any feature default settings.
Ian Chapman
Message 7 of 14
kalpeshpote
Message 8 of 14
ianjchap
Ah, thats annoying.
My OOTB template (UKIE) has the 'Civil 3D Standard Text' style applied to all features. And this can be changed.
It may have to be opening up each feature and swapping out the Label Text Style with a new one. I cant see an overiding way of doing this. Hope someone can prove me wrong on this.
Ian Chapman
Message 9 of 14
ianjchap
Try right clicking on the drawing name in Settings and hit the Edit Label Style Defaults.
Ian Chapman
Message 10 of 14
AllenJessup
I change the Standard Style to have whatever font I want to be standard. I only make other styles for text I don't want to be that font.
Allen Jessup
CAD Manager - Designer
Message 11 of 14
Joe-Bouza
Modify Standard to the specifications you want. font, etcetera
Joe Bouza
Message 12 of 14
tonykB72MP
CTC Software has a tool in their civil products, CIM Manager Suite called Template Tracker that will allow you change any object or style using any text style to another that resides within your drawing. Open Template Tracker, set objects to text styles, select a text style and it will show you every reference that uses that style and then you can select multiples to swap with any other text style in that drawing.
Message 13 of 14
Joe-Bouza
It also sounds like you want to link the template and that is possible the the software OOTB
Joe Bouza
Message 14 of 14
MMcCall402
I think ianjchap in response #9 has the right method for this.  Just be sure to press the child overrides and it will force that text style into all the label styles.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
