Civil 3D Forum
Structure Profile Labels
1 REPLY 1
kubastan89
268 Views, 1 Reply
I`d like to ask you two questions:
1) Is this possible to attach profile label to structure bottom ? I tried different settings but I wasn`t able to do that.
2) Is this possible to create label with line component that is attached to structure bottom and profile view bottom axis ?
I was able to generate this line by showing Grid at horizontal geometry point but I have to make sure here Alignment PVIs are exactly at structure centre.
It would be easier to create just line component in structure label.
Labels (1)
1 REPLY 1
cwr-pae
in reply to: kubastan89
Like this?
Set the option for label Dimension Anchor as Shown here:
Set the end anchor for the line component as shown here:
To make this the default set options here:
If you set the structure label placement as Bottom of Structure you may have to reconfigure the text components order.
Rail Community
