Catchment from object - will not accept coefficient
- Mute
- Permalink
- Report
I will be starting a massive project shortly with a very short time deadline. I thought I would try catchments again since I already have half of the inlet areas defined as closed poly lines. I did two small pipes as a tutorial.
I used - Create catchment from object - picked poly line - esc to ignore TC as I want to enter manually.
It then prompted for the rational coefficient - I typed in my computed value.
When I checked catchment properties, it had refused to accept my value and had used the default value in the settings.
2014 - Has this been fixed in 2016 or 2017?
Ann Wingert, P.E.
