We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
CANNOT ADD CONTOUR LINES TO THE SURFACE
sanetdikkumbura1950
sanetdikkumbura1950
Cannot add contour lines to the surface. But it is shown in properties as contour lines. Why?
Please Help
rl_jackson
Your contour lines are AEC Contours from LDD (Land Desktop), If you don't have the original DTM file, TIN Lines or 3D Faces from the original file then I can't think of a way to explode them without having LDD installed. You could trace over the contours with a 3D polyline at the prescribed elevation of the contour which could then be added to the surface in C3D.
Rick Jackson
Survey CAD Technician VI
Pointdump
Hi Sanet,
Thanks for posting your drawing.
In addition to excellent advice from Rick @Anonymous, those contour lines don't even have elevations, which is really strange, so you can't add them to your surface as contours.
Basically, you haven't defined your surface yet.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
AllenJessup
Doesn't look like it's possible. You'll probably have to trace over them with 2D polylines at the correct elevation.
Allen Jessup
CAD Manager - Designer
