Civil 3D Forum
Can you place a block on a tin surface and have the same z value as the surface elevation?
1 REPLY 1
martin.hong
161 Views, 1 Reply
Hi all,
Basically right now I am placing a lot of tree blocks on a plan and they all need to be at a specific elevation. Currently I am placing the block, adding the spot elevation, then manually changing the z elevation under each properties to match the spot elevation.
Is there a way to quickly place the block so that wherever it lands on the tin surface, its z value matches the exact elevation at that point on the surface?
I attached a pic for reference.
Thanks!
Labels (2)
1 REPLY 1
user181
in reply to: martin.hong
There is a command _AeccMoveBlocksToSurface that will move all the instances of a block to the surface. So if you placed all the blocks and then ran the command it would move them all to the surface elevation.
Rail Community
