Civil 3D Forum
Background mask not working
11 REPLIES 11
Message 1 of 12
27096 Views, 11 Replies
I can't get background mask to work on one dwg
I can go into another drawing on my machine and it works just fine
it looks like its working until I zoom in or out then it doesn't work at all
thanks for any help you can give me
                                  dj
11 REPLIES 11
Message 2 of 12
AlmasSuljevic
Can you set the background mask all the way back using DRAWORDER? Then lock that layer where background mask is and see if that helps.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
Message 3 of 12
Crass
I am having this issue with a rotated dimension. When I use TEXTEDIT I can apply a backrground mask, but it does not "take," meaning that when I close text editior, there is no mask regardless of draw order. When I open the PROPERTIES pane for this dimension there is no option for background mask under the Text category. I do have this option for leaders and it works perfectly.
AutoCAD 2018/2021
AutoCAD Civil 3D 2021
Message 4 of 12
mathewkol
Dimensions have a different setting than text; it's not called background mask. Look in the dim style editor, text tab and you'll see background colour (I think that is what it's called).
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
Message 5 of 12
Crass
in reply to: mathewkol
So, you have to create a unique DIMSTYLE just for background masks? You cannot do an object override
I just realized I am in a Civil3D forum. My issue is in AutoCAD LT. I have not yet tried this in Civil and am not sure if these commands/ objects are the same.
Thanks.
AutoCAD 2018/2021
Message 6 of 12
Under properties
go to Fill Color, set it to Background
Tags (1)
Message 7 of 12
kehale
I don't see an option for background color on my Appurtenance label style.
Message 8 of 12
mathewkol
in reply to: kehale
It's called background mask within that style.
Matt Kolberg
Message 9 of 12
kehale
I have that box checked.  The only way I have been able to mask the pressure pipe labels is to make dozens of wipeouts.  Draw order helps.
Message 10 of 12
Have your labels been dragged? If so, there is another setting in the dragged state within that style.
Message 11 of 12
mwsmithZJDF4
in reply to: kehale
I'm having the same issue with Civil 3D 2023 for both pressure and gravity pipe labels. Did you ever find a solution other than the wipeouts?
Message 12 of 12
mwsmithZJDF4
in reply to: mwsmithZJDF4
Update -  I was able to get the background masks to work by switching my PDF plot settings to "lines overwrite" instead of "lines merge"
Rail Community
