Can't uninstall Civil 3D
Win10 x64 1909 Pro on a home computer
Civil 3D 2020
When trying to uninstalling it, it shows an error:
Failed to load
c:\users\yingx\appdata\local\temp\_ai63d7.tmp\setup\contentpackui.dll (127)!
after press "OK", it shows another error:
ContentPackFinalize was not found in
C:\users\yingx\AppData\Loca l\Temp\_AI68D7.tm p\Setup\ContentPackUl.dll!
The reboot doesn't solve the problem.
How to solve it?
wfberry
Just substitute 2020 for all 2019's for a clean uninstall.
https://knowledge.autodesk.com/support/civil-3d/troubleshooting/caas/sfdcarticles/sfdcarticles/2019-...
Bill
lynn_zhang
Hello @Anonymous ,
Just checking to see if your problem has been solved. Did the response from @wfberry help answer your question? If yes, please click on the "Accept as Solution" button in his reply so this helps other users in the community find the solution too. Thanks!
Lynn Zhang
AllenJessup
This Microsoft tool might also help.
https://support.microsoft.com/en-us/help/17588/windows-fix-problems-that-block-programs-being-instal...
Allen Jessup
CAD Manager - Designer
