Civil 3D Forum
Can`t purge block
5 REPLIES 5
tummeiJSL3D
451 Views, 5 Replies
Can`t purge block
I ran into a problem where I can't purge blocks. I tried many things but it does not seem to work.  I think the block is somehow linked to "AECC_LABEL_BLOCK_STYLE (2)"  but  I do not know how to locate the block style in order to change it. If you have any suggestions please be free to help me.
Thanks in advance
5 REPLIES 5
@tummeiJSL3D
Please check attached file
it was inside piketai and piketai forma 7 band label style.
Beka Tchigladze
Road/Highway Technical Designer
AEC Collection/C3D 2025
WIN 11 64 PRO
Predator Helios 18, Intel Core i9 14900HX, 32 GB
NVIDIA RTX 4080, 12 GB
YouTube--->Linkedin
Thanks for such a quick reply. Also, I am wondering how did you know what label style to delete? Because I also want to delete all remaining non-purgeable blocks. Again, thanks for help 🙂
According to the Gost standard this is a km mark of alignment and there was only 2 option. It could be the block inside alignment label or inside profile band, in Gost standard there is not any other style where designers use this mark.
If you want to create your own template, take a blank template and build your own template from black one. As I saw you have tons of Russian standards in your template. you can just copy necessary for you in the blank template and get rid of others.
I find this one easily, because I knew where to find it according to some experience with Russian template.
Beka Tchigladze
WIN 11 64 PRO
YouTube--->Linkedin
tummeiJSL3D
in reply to: tummeiJSL3D
Yeah, probably it`ll be easier. Thanks for advice
alonva
in reply to: Beka_Tchigladze
Hi! I have a similar problem, but I have removed all styles
Rail Community
